[WANTED] Early A body S6 to V8 swap parts
saldiek
Member
Hamburg, Germany
Rating - 0%
0   0   0
Hey together,
I am looking for the parts to swap my early a (1964 Dart) from Slant to V8.
Meaning I need the gas pedal, centerlink, throttle and kickdown linkage, and potentially a sb pushbutton 904
If you have things to sell please let me know
BR
Simon
Don’t forget you will need motor mounts, and a V8 radiator. Are you doing a stock 273 or will it be a hot rod?
Don’t let someone try to sell you a “V8 k-frame” ….1963-1966 slant six and V8 are the same. If upgrading to a V8 it’s also a good idea to get V8 torsion bars and bigger 10” or disc brakes…also the stock 7 1/4 rear won’t hold up to a V8 unless you plan to never get on the gas hard.
It will be a 273 but not fully stock. Thinking about 360 heads with quad carb, was the recommendation from a local mopar enthusiast who did it already in the past with very good results. But for sure I will need some manifolds. As it is the early k frame I guess it will work with the stock setup. Sure I was thinking about converting brakes and axle but I guess I will do that at a later stage and start with stock. At least there are already powerbrakes retrofitted ;)
