Early A body upper ball Joint Socket
Dart fan
Monroe
can anyone help me find the correct socket to remove the upper ball Joint Socket. 1.803?
I’ve purchased two that don’t fit .
Looks like this is the one you need. ^^^^^Post 2
I will have to look at the one I bought a few months ago but the size 1 59/64 is what I'm thinking.
I purchased the 1 59/64 and it doesn’t fit ? I heard there is two sizes for the early darts .
What year is the car? Has it been upgraded to disc brakes from a newer A Body
If you pull the boot, there's usually enough room to get a pipe wrench onto the ball joint from the underside of the arm. Once you break it loose a large crescent wrench can spin it out.
Thanks for all the info I will keep trying
