66340SEDAN
FABO Member #3649
For sale is a nice used V8 firewall throttle bracket assembly for 64-66 A-Body cars, should also fit 63 models as well. This is what you need when you swap over to a V8 from a slant six, it bolts right to the firewall, all you need to do is drill out the holes, the holes are even dimpled on the firewall so there is no guessing where it mounts too...eazy peazy!!! The foam gasket is still good, also has the small bracket that mounts to the front side. Just needs to be cleaned up and painted....sorry, I do not have the rubber gas pedal. This is factory stuff, not that cheap aftermarket junk. $55 shipped to your USA door. Sold as is, I am in central MN, Thanks FABO :glasses7:
