fstfish66
ok i have a set of large tube headers 1 7/8 or 2 inch i forget, custom built,these will NOT fit a stock suspension stock steering A body,,,i had a custom front end with rack and pinion,,and rear sump pan blower motor,,these are not the prettiest header ever made,,but will do the job if you have a custom suspension that they may possibly fit,, you would fall over laughing if you knew what these cost,,, i took them off and had a nicer set made,,,the car is gone now so i have no need,,,if they fit your application its a ton of savings for you,, they may fit any A body with custom suspension or straight axel,,,
pick up only asking 100.00 obo located out side philadelphia pa
thanks for the add abodies
