Early A Hydraulic Clutch.
cmac64dart
mays landing nj
I know there has been other threads on this but I'm looking for a couple pictures of the pedal set up on your hydraulic clutches. I am considering modifying the stock set up. I ordered a pedal from wildwood that might work. I'm more curious to see what u guys did. Thanks, Chris
Just an update. I used the wildwood pedal in the speedometer opening in the firewall. I had to beef up the area . Cut the existing clutch pedal and welded the the remaining piece back to the steering tunnel. I'm not finished, I will post some pictures when I get closer to finishing
