Early A throttle cable
cb66valiant
Wheeling, WV
Just put a 750 Holley on my 340. While checking for "full throttle" my throttle cable broke at the pedal. Years ago the same thing happened and I installed a ball with a set screw in it. Worked well, until now. I need to just replace the cable. But don't tell me Layson's is the only place to get it!
Thanks
cb66
I have a used 1973 Duster 318 2bbl throttle cable on my 66 Valiant 340, works great, even with the high rise M1 intake and 1" carb spacer. I am also using the stock 66 a-body gas pedal setup and Holley 750 carb. I would look on ebay, there should be several in junkyards too.
66340,
Do you think the 73 duster 2 bbl cable work with a Edelbrock performer intake? Would it be to long?
Thanks
You could try it, there should be a little adjustment in how it is mounted on the bracket. If I remember correctly, the 318 cable I used was the same length as the one I pulled out of a 66 Cuda 273 Commando car, I would have used that but it was no good, so I took one from my rusty Duster.
http://www.imperialservices.net/Imperial Services - '60-'72 A-Body Parts.htm
1964-1976 Throttle Cables
These new Throttle Cables are made of premium materials for long life and good looks. Billet stainless ends are fitted to a nylon lined housing, with a stainless steel inner member and clevis. Special lengths and custom ends available by special order.
Throttle Cables
Application
Our Part Number
Replaces OE PN
1964-1966 V-8 IS-511 2465 487
1968-1973 A-Eng IS-531 2899 336
1969-1976 Slant 6 IS-532 2899 335
1971-1976 V8 4Bbl IS-541 3577 523
Throttle Cables are $65 plus shipping
