[SOLD] Early A Variable Speed Wiper Motor & Switch
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
Up for sale is an early A variable speed wiper motor with linkage and wiper pivots and the variable speed wiper switch. This came out of a running 65 Dart I parted out. This should fit 63 through 66 A Bodies. You will need to fabricate a 4 wire harness (double male at the switch double female at the wiper plug or if upgrading from a single speed, add one 2 wire harness and reuse your current 2 wire harness. Asking $75 for everything plus shipping from 22657.
img_5988-jpg.1714876287
[ATTACH
img_5989-jpg.1714876288
=full]1714876287[/ATTACH]
img_5991-jpg.1714876290
Hi Dave - motor and switch came out of a running driving 65 Dart GT I owned since 84 and finally parted out last year. The number I found on the wiper switch is 277 0377.
I am wondering if my variable speed setup is the reason we can't get an intermittment regulator to work as we have in other cars. If it were possible to convert to a 2 speed setup, maybe that would be the fix. At least with the results i get, the variable speed wasn't all that different
Hello,
What do you mean that it was not that different?
Which regulator is intermittent?
