[Found!] Early slant six flex plate
Manuel
Central CAL
Early slant six flex plate for a 904, 10" outer bolt pattern the center hole is 1.962 , all I've been able to find new are the ones with a larger center hole.
Thank You
should have that, and they are not same as 273 cranks.
Ill confirm weds.
If that first one doesn't work out I've got this one.
