[WANTED] Early v-8 gas pedal
just poted the wanted item of a early v-8 gas pedal, I didn’t post for what kind of car. It’s for my 1965 Dodge Dart GT Convertible . Hope this clarifies any mix up.
Thanks,
Tom
You can find them new repopped on eBay for $60
the repops don't have the rub pad on the back where the throttle paddle rubs the pedal! Nor do they make that piece!
If you need one, I have a few extra! Just the pedal tho, I don't have the rest of the assembly!!
If you have no luck finding one,I have used the early B body 62-65 assembly.You have to drill new holes to mount the pedal.Other than that it works fine.Did it on my 64 Dart.
$119 ea plus the ride. they have different length cables (I can measure) & one has the stiffener plate & one does not. On one, the cable is not OE but is functionable. Holler if desired & we will go from there.
