MopaR&D
Nerd Member
Just did a quick search, people on other forums are saying if it shuts off when it gets hot either the ECU is bad or a sensor is bad. Since it starts running when you cool off the ECU itself it's probably bad. I would try hitting up some of the other Gen 3 Hemi tuners such as Modern Muscle, High Horse Performance, Arrington (shophemi.com), Hemifever Tuning, or even DiabloSport themselves. Try to find a company with experience in tuning ECUs to run in older vehicles.
Remember you're trying to run a 10-year-old engine so most of the used ECUs out there which are compatible are probably going to be around the same age and were more than likely pulled from a wrecked car/truck. Lots of people still driving around 2007 Dodge Hemis here in the U.S. On that note there should be new replacements still out there...?
