Hopefully this will find it's way to the right people.
Motor Specs are below.
Carb is Eddy 1405 with stock jets, needles and orange springs.
I have purchased an ASPX D2 Air/Fuel Ratio Gauge (Not the most expensive and not the cheapest, reviews are good and I have a friend with it and it's accuracy is pretty good when compared to his OEM system) and an Eddy 1479 Tuning Kit.
My engine currently runs rich judging by the plugs and the exhaust.
On to the questions:
1. How do I know which step up springs I need?
I read the instructions and it doesn't seem to cover that. Only 'Trial and Error'
2. If I take the readings from the AFR, How do I know how much to adjust?
The tuning guide shows adjustments in 4% increments.
I will be installing the AFR in the morning and then starting this tuning process and I am trying to gather as much info as possible before I start.
Thanks for the time.
rayer:
rayer:
