360duster
Now I have a rod question. It has the 68x47 rods and I do have the tuning kit. Which number is the power and cruise numbers? is the larger the power or is it the cruise. If I want to go richer do I use a 65x47 or a 68x42 rod?
Thanks all!
The first number is the cruise adjustment, the last number is power (smaller diameter - more fuel trough jet). When you want the cruise mode richer use a rod first number lower, when you want the power mode leaner use a rod with second number higher for example - ok?
Michael
