Do you think, on a stock 318 the eddy 1403, 500cfm carb vs. The 1406, 600 cfm carb give any advantage on fuel economy or just be a moot point?
It is for my stock Ramcharger. I already have the 1406 on it and runs great. Just wondering if I could squeeze a little bit more out of it.There'll be a bigger performance advantage to the 600 than mileage advantage with the 500.
Order and play with some rod/jet combos on your 1406. Cheaper and easier option.It is for my stock Ramcharger. I already have the 1406 on it and runs great. Just wondering if I could squeeze a little bit more out of it.
I am hoping to get about 15 mpg out of it. I'm not that far from it now. Its gotten the best with the 1406 on it. I even thought of an AVS2 . I'll keep playing with it.Probably not. It's just a guess though. But a serious question...."how much more" if any do you think you'll get?
Minor things all ad up. I had a 1983 4x4 Ramcharger. Air up the tires, drive like there is an egg under the accelerator pedal. Accelerate away from lights and stop signs easy. Let off the gas when the light up ahead turns yellow. Fresh oil change with efficient oil. Fresh rear diff lube change.I am hoping to get about 15 mpg out of it. I'm not that far from it now. Its gotten the best with the 1406 on it. I even thought of an AVS2 . I'll keep playing with it.
Gotcha, sorry. My thoughts were that if I used a smaller CFM carb, that I could possibly get a little better fuel milage, whatever it was. Every bit helps, but I understand what you mean about the smaller carb could actually negate any gain expected. I am constantly trying to improve it. I love the snot out of this beast and at times, prefer to drive it over my 2018 Ram.Kinda not an answer to my question. I was askin what kinda "difference" do you think would be from the 600 to the 500? In other words, if the 600 gets 15, how much "more" do you think a 500 would get? I bet it's even possible the 500 "could" get less mileage, IF it puts you in the situation to whee you're using "more" of the carburetor, if that makes sense. 15 is pretty good for a big rolling box on wheels.
I'll look into changing the metering rods next.
Thanks!
Timing is my next plan I think. I just replaced the distributor with a new one a few weeks ago and a set of the e-core plugs. I picked up a noticeable improvement from that. I enjoy tinkering with the Ramcharger over my Duster most days, plus I enjoy the challenge of trying to reach my 15mpg goal.Playing with it is what I do as well.
Even if it’s already really close just for something to do on it.
I’m just a bit rich on WOT, so I’ll be playing with that before long.
If you have a way of seeing the A/F ratio you can get down to the wire with it, but even then what the motor wants sometimes varies from what the gauge says is perfect.
Just a FYI, I was getting right at 17mpg in my Dart after tuning and tuning again.
When getting that specific about it everything matters right down to your timing, including you vacuum advance .
