[Found!] Edelbrock 7176 or LD340
I have this style intake with the factory AVS for a 70 340 4spd. it also has the factory choke spring, It is in almost perfect condition very clean and assembled. If interested I will take pictures. I will not separate it unless someone buys the intake only. I will not sell the carb off of the intake.
It came with a 70 340 4spd car it was in the trunk . It doesn't look like it was ever installed. if interested I can get pictures then make me an offer.
The picture below is a picture I found of the intake on the web . But this is the exact intake I have. It also had the 4bbl throttle cable bracket and complete 4bbl gas peddle assembly which has a shorter cable then 2bbl with it if required. and all the factory bolts to install. I believe the gaskets are also there and the thermostat housing. I'll get some pictures when I get to the garage. I fractured my arm and I am in the house on pain meds.
