Edelbrock LD4B layout
tanis4457
Mountlake Terrace, WA
I recently acquired a LD4B intake for my 273 and since I've never swapped an intake manifold before I was wondering what some of the extra ports are for the intake manifold. I looked around on the web and on Edelbrock's website but couldn't find the info I wanted. So I was wondering if you guys could help me out?
I tried to get the photo to link directly to my post from my google drive but I couldn't get it to work.
1. inlet in water passage for??
2. what is the tube over the temp sending unit for ??
3. inlet in water passage for???
4. vacuum port??
5. plugged valve on exhaust passage?
6. dont know??
7. vacuum port??
https://drive.google.com/open?id=0B4jhnfPRd2C8UTBLNVM0MTNVWFE
The numbers correlate to the ones in the reference picture:
1. Stock water temp sensor.
2. Heater hose attach.
3. A/C mounting boss
4. A/C mounting boss
5. EGR port hole --> keep it plugged
6. Mounting boss for some bracket that i've never seen before - leave open
7. Vacuum port for power brake booster or vacuum attachments --> use if needed, keep plugged if not...
You would use #7 if you have a Performance Indicator (vacuum gauge).
