ssba
Up for sale is some very nice clean 440 parts I put together for a car I no longer have.
The manifold is a old school edelbrock tm7 single plane with no thread or bolt hole problems.
It has been coated with autobody urethane clear for a easy to keep clean durable finish.
Not spray bombs. You will need to use a valley pan with the heat block offs on this one.
The Holley list# 4781-6 with 4 corner idle. I have added some new Holley accessory chrome
parts that include 50cc & 30cc pump covers, choke cage, fuel bowls. and hard line.
The carb has out of the box stock jetting and squirters and pump cams. Mechanical choke, throttle shafts all work smooth as new.
I also comes with new stainless manifold bolts and wingnut. Carb studs are also new.
The 1" phenolic spacer is used as is air cleaner tins. New paper filter.
The carb will need new gaskets. I never put them in till I am ready to put carb to use.
400.00 + shipping.
I could install the gaskets for the price of a kit if that would help someone
that wouldnt be doing their own carb rebuild.
This has always been one of my favorite manifold carb combinations for a quick street strip
440. No bad surprises or dissapontments just nice parts. Feel free to ask questions or add your comments on the post about these parts to help this find a happy new owner.
400.00 + shipping.
