1972DusterPaul
$150 + Shipping from 48167 (Northville, Michigan)
Used Edelbrock Performer RPM Intake 7176 ready to bolt on.
Only bad is...
the rear coil mount bolt is broken off in the hole. I couldn't drill out the bolt, it just dulled my drill bits. But what I did was cut off a bolt short and used lock-tight on the threads. The front coil mount hole is fine (so the coil is secure) and I will throw in both coil bolts along with the bolts I used to hold down the manifold.
Other than that it's in fine shape.
I bought it used and the previous owner failed to mention this. I originally paid $150 + shipping so that's what I hope to get back out of it.
Thanks FABO for the ad space,
Paul
Only bad is...
Paul
