I have a 600cfm manual choke edelbrock performer carburetor that is not even a year old yet and doesnt even have over 5000 miles on it and i just noticed something that really pisses me off.
The throttle shaft on the drivers side is leaking fuel, i sprayed carb cleaner there while it was idling and the idle smoothed out considerably... So also a VACCUM LEAK. I'm sure many of you know that i hyave had a hell of a time tuning my engine and i think it's pretty safe to say that this is why.
I have changed intake manifold gaskets looking for the vaccum leak, wich i did have a vaccum leak at the intake, so it wasnt a total waist of time.
But man i have been pulling my hair out trying to figure out what in the hell is wrong with my engine and i am pretty darn sure this vaccum leak at the throttle shaft is the culprit, because its a fairly good sized vaccum leak, the idle drops quite a bit when i hit the shaft with carb cleaner.
So today i purchased a brand new 1806 edelbrock 650cfm vaccum secondary electric choke thunder series carburetor. I figured i would stick with an edelbrock since i have 3 or 4 different strip kits with jets, rods, springs, different accelerator pump squiters and accelerator pumps and i also have multiple books on the edelbrock carbs and i am most familiar with them.
I just wanted to ask if there is anything i can do besides running a softer throttle return spring to keep the throttle shafts on my thunder series carb in good leak free shape? I don't know if my return spring is to blame for the shafts wearing out so fast on my performer, or if i got a lemon from edelbrock? Or if i was too hard on it? I just dont know, I couldnt believe it when i saw it because this performer is barley a year old with hardly any miles on it. Also is there anything a guy can do to fix this issue? I opted for the 650 thunder series because i wanted an electric choke and vaccum secondarys anyways and i planned on getting a thunder series to replace the performer series anyways, it's just it happened alot quicker since i discovered this issue with the performer series.
