[WANTED] edellbrock carb part
moparraceman
mansfield ohio
need rod and spring that operates the accelerator pump lever on a edelbrock carb, maybe a carb rebuilde,r or some one who has a parts carb they could take it off of will pay part and shipping to 44905 ohio thanks
no i made a mistake its a carter carb, small rod that fits in the second hole of the accellarator pump plate, and goes down to a bracket that on the throttle bracket if you have one post a picture and i tell you if its the right one i cant post pictures thanks
I am almost 100% certain that rod is the same on the Carter and Edelbrock. I have one, but it's on an Edelbrock carburetor and it's not a parts carb. If you don't have any luck, I can find an appropriate length and diameter of rod and make you a copy.
