[Found!] EGR Block off plate slant six
They removed the EGR from the Chrysler minivan 3.3L/3.8L engine somewhere in late 98 to 2000 and used an EGR block off plate that is the same geometry as the old EGR's... Go to a dealer and look it up in the parts book and order one...
Get a EGR gasket and trace it out, cut it out of a steel plate, drill out the 2 mount holes, sandwich gasket between fresh cut plate and manifold,bolt it on and there ya go
This is a picture from the internet somebody Incorporated some heat shield over the intake manifold but it is a slant six one barrel with egr same thing as a 2 Barrel, that hole right under the carb needs to be tapped and plugged.
Hello, sorry for the delayed response, we were on vacation.
Yes, I still have and sell the EGR block off plates, along with the exhaust block off plate. They are $11.00, plus shipping. Just let me know if your interested. Thanks Marcus
Yup and the exhaust block off would be for the bottom of the intake for when you run headers
Ok so it looks like I found what I originally set out for thanks to @Marcus V.
I look foward to seeing the mail show up with a bolt on part for a mopar :D
Thanks so much fabo
