EGR delete on a 2007 Charger 5.7 Factory intake
5258
Middle Tennessee
Trying to get ideas how/what everybody is using to block off the EGR tube hole behind the throttle body. What is the best solution there?
Thanks
Mike
Thanks
Mike
I had considered using a 1" freeze plug, but ended up using a 3/4" pipe plug with RTV on the threads. I then made a 1/8" thick plate to match the shape of the old EGR flange. I haven't run the engine yet, but it will be fine.
Friend of mine cut the tube and did the freeze plug thing. Been working for years.
