dartslantsix
I’m starting to dig into which swap harness I’m going to purchase. That has taken me down the rabbit hole of electric fan control. I’ve got a 2010 5.7L from a Police Charger and I’m planning to use the radiator and dual fans from the Charger.
It appears that 2014+ PCMs can control the fans and the swap harness is set up to do this. Can I update my engine to use the newer PCM? I’ve heard there was a reluctor ring change in 2014 that may prevent me from updating to the newer PCM. Can anyone confirm?
If I can’t go that route, there are a number of electric fan controllers and/or relay systems to run the fans. Are there any recommendations? I’d love to go pulse width modulation (PWM) if there is an affordable controller that is reliable. I’m seeing mixed reviews about some brands that die randomly.
Lastly, is there a way to figure out how many amps these fans pull?
Thanks.
Thanks.
