Electric Fuel pump and lines
If you have a fuel cell run a 1/2" line all the way to the front to your regulator. Come off the regulator with either a single line or double line to your carb your choice. Don't forget to include a filter. Summitt also has plumbing kits in their catalog.
there are so many options its hard to tell you what to do.heres what i did. 8an from regulator to filter and a dual inlet for a dominator with a gauge om the end so i can tell if the fronts starving on high rpm pulls. its not near as close to the header as it appears in the pic.
