Electrical grounding question
Just another note, electric code says no more than 360 degrees of bends between junction boxes, 6 nineties won’t pull nicely, max of 4. If it’s plastic (pvc) pipe you will have a good chance of breaking it, the rope will burn through the corners or the wire will break trying.
Yeah that's why I cut into the wall of the garage to bypass two of them and I'm trying to dig down near the barn to bypass two as well. Once I get the wires fed through the long straight portion, I can then easily feed them through the rest of the 90s.
If you can get the pipe empty then get a string and tie a ball of yarn (like the ball on top of a stocking cap) to it. You should be able to suck it through with a vacuum. Good luck
