Punkmastadart
- Joined
- Feb 24, 2008
- Messages
- 87
- Reaction score
- 1
I just had a quick question, is the electronic choke on an edelbrock 600 wired directly from the battery or should it go through a choke solenoid first??
I got this choke solenoid so ill just run it through that Thanks a ton for all the help!!
the choke solenoid was wired to a choke preheater, the main choke control was the heat of the intake manifold. with your true electric choke wired that way after 5 mintues the choke wont have power and will close. the electric choke needs 12 volts whenever car is running.
