Emblem Dilemma
Rbob
Olympia, Washington
I have a 67 Cuda and I replaced the driver fender with a 69 and welded up the market light.
Them emblems are different on the 69, smaller I think.
The fender is painted, so now I can get 69 emblems and not worry about it or weld up the holds re-drill and repaint.
What would you do?
If you grind the studs off the 67 emblem could you glue them on with emblem adhesive? Would it cover the holes? If not, I would use the 69's.
You can't look at both fenders at the same time! I saw a brand new Buick one time where the factory put "Limited" on one fender and "Custom" on the other!
