Emergency!!!! Alternator not charging and I am in the middle of a drag & drive!
Clelan
Inferno Red Duster
Martensville Sask. Can.
The wiring from the ignition run to the voltage regulator field junction (goes to 1 side of the field and jumps to the voltage regular blue wire) melted to ****. I noticed it because I went to swap let's in my carb and there it was. Fortunately I was close to home so I grabbed a known good alternator and voltage regulator from a running driving daily driver truck and swapped them on to my car. I replaced all the melted wiring right to the junction point with the ignition run wiring. I also replaced the wiring plug on the voltage regulator because I had one.
I didn't have time to properly diagnose, So I shot the parts cannon at it but it still does not charge. I have 12.24 v at the battery, 12.12 v at both sides of the alternator field ehen running. It does not increase with RPM. What am I missing? What voltage should I read at either side of the field terminals?
Cley
Amp meter is bypassed. I tried a ground jumper to the alternator case, no change. I tried a ground jumper to the voltage regulator, no change! Measuring voltage with high quality volt meter at battery and Autometer volt meter in dash. Both are matching.
Cley
Yellow wire ran to replace melted wire. Tried connecting it directly to battery, no change.
Cley
Based on your description you have an isolated field alternator.
One field terminal gets 12v, one get a variable ground from the VR
Is the doner alt and VR both isolated field parts?
If so the VR body MUST be grounded and a 12v source attached to the (blue?) wire to the VR
The green wire from the VR goes to one of the alt field terminal.
Another (typically blue) wire goes from a 12v source to the other field terminal on the alternator
I figured it out! The parts store Voltage Regulator plug did not make contact with the pin for the green wire on the voltage regulator. I stole the plug from my other car and I'm in business!!
Cley
