Emergency park
Burnnin Charlies
North carolina
Okay I need this clip it is the clip at the end of parking brake line that holds it in the frame under driver side of car. Any part number or links I appreciates it
If the clip is there to keep the sheithing in place you could substitute a 1 way washer
it is the same as the one that holds the ebrake cable on the brake assembly under the dash in the pickups. i try to get one every time i find 1 in the junk yard. say a bunch of them at indy. will try to remember the guys name and post it for you.
