Thanks StrokerScamp, just to be safe I will probably use that on the timing cover and water pump bolts. I have a whole tube of the red permatex, as far as the exhaust goes is it just the end studs that require sealant?
And the head bolts don't require anything correct?
Thanks for all the help
