moper
All are in Eastern CT, 06237, town of Columbia. Pictures by request. Can ship world-wide for crating/shipping costs or can drive up to 200 miles for gas/cheeseburger money to meet you. Also can provide complete performance and restoration services by former ASE Master Tech, mild to wild, tune ups to full restorations, references available. Sonic testing available.
'65 273 long block. Stuck fast - no oil pan, valve covers, or rockers included but does includes 2bbl intake, timing cover, balancer, and iron water pump - $50
'70 cast 340 block - numbers not visible (rusted away) - cleaned and magged, 1 bore sleeved years ago, std bore, surface rusty - $400
'67 383 block/crank/ & rods - magged, std bore, all are rusty - $150
'76 400 block - std bore - $300
'74 440 cast crank - haven't measured but should be std/std & looks good, will include balancer - $100
273 mechanical rockers, shafts, and pushrods - $200.00
Slant 6 oil pan - $25
64/65 273 cast iron marine 4bbl intake - $40
Core set of RB "LY" rods - $20
Core set of B wedge rods - $20
late model 360 4bbl modified with W2 bolt pattern - $25
'65 A904 trans core - no cables, with flange output & small input & matching stock convertor - $200
'65 LA Power steering pump & bracket - not frozen but haven't seen it run either - $50
'65 273 B body manifolds - $40
mid 70s 413 - short block - turns with socket, clean, reportedly was a running unit & looks the part - $400.
"516" head castings - bare, magged but rusty - $150
