moparman1
junior member
can anyone tell me what size engine this is,4006830-360-2 . its a 1975 engine. I was told it was a 318 not a 360.
Its a 360, hence the 360 in the serial that is cast in the side of the block...
haha cant believe he thought it was a 318. Heck $100 for a 360 block is a pretty good price imo.
Not quite. Unless it's one of the M-body cop car 318s, the exhaust ports on the 360 are larger. Oil pans are also different. Check diameter of front main bearing with the balancer off. If carb is on motor and a Carter 2bbl it's a 318, the 360s used Holleys. The 360s, if it had a 4 bbl was a Thermoquad. The M-body cop car had a Quadrajet on the 318.
