engine ID also?
If its a big block it could be a 361-383-413 engine. Don't know what the codes mean but those are the big blocks of that time period.
Do you have no idea? Try the Year One site at; http://www.yearone.com/updatedsinglepages/id_info/mopar/mopar casting numbers/castingnumbers.html ,it may be able to help you out. But when I tried researching your number, I came up with a Hemi!!! Now if it is a 440, their should be a small, flat area on the front drivers side in front of the intake manifold. Opposite side of the distributor. There should be stamped numbers there. 440's are the only engines with this flat area ans stampings. I have pictures of the area I'm talking about if you need them.
