63dartman
I am now ready to set my new engine with the spic and span valve covers(another post) into the engine bay. I am a little worried to use the lifting plate that bolts to the intake. It has 4 5/16" studs in the eddie manifold. Is it safe to use the plate or should I lift it from a couple of intake bolts that go into the heads? I just have visions of the studs pulling out of the aluminum intake. Right now it is on a stand until I know for sure. Thanks
