Just the same old skinning of the cat argument. People get pushy and even rude about how to do it and its unnecessary.
It’s not being pushy or rude when the ONLY way to do it is mill the heads. Specifically when it’s said if you do the heads, any intake can be slapped on there after that, and that is bullshit.
I don’t know how many small block chryslers you build, but if you want the compression ratio where it should be, you can mill .080 off easily. Especially when the nominal deck height is mostly on the high side of the blueprint or over it.
I need to measure the deck height on my R block again. Seems like it was 9.650. To get to a zero deck with most pistons you’re going to take off .060 anyway.
If you are using an open chamber head like a W2, and you don’t want to use a King Kong sized dome, the piston has to come out of the bore. IIRC, the OE gasket was .029 thick, or close to it. So you either need to mill the piss out of the heads, which kills flow and makes it harder to keep a head gasket sealed, AND you still need to either mill the intake manifold or the head face, or you take it off the block.
This ain’t my first rodeo doing this. Decking .040-.060 to set the deck height is normal if you don’t want to run a huge dome. Or 9:1 compression is what you’re after. To get an honest 10.5:1 on a 340 the piston has to be out of the deck at the very least .017 PLUS the difference in the thickness of the gasket from OE to aftermarket.
And, if you are building compression on something like the junk W5 chamber, the best way to do it is stick the piston out of the bore an extra .040 or so, mill the deck of the piston down whatever you took off the block, and reduce the dome if you can.
That’s how you can get 15.5:1 on a 3.313 stroke and not run a King Kong dome.
And it’s the same for most anything running a dome.
In any event, you need to mill something, and the intake is cheaper than the head to replace.
