Hi, I’m Gene. I have a 1970 Duster w/ Factory 340. I’ve switched to DC electronic ignition years ago. I’m having trouble when Im opening the 4 bbl it seems like it’s loading up or not burning the fuel properly. It idles fine and sounds fine in the primary’s until I open the 4 bbl. It just sounds like is holding back or not burning the fuel properly. I have new plugs , wires, cap and rotor with a fresh Holley 750 dp w/ manual secondarys. It’s all been set properly. I have done a coil test of the primary and secondary windings. They are within tolerance. Could the ignition module or voltage regulator cause this issue? I’ve had this car for 43 years and it’s always ran very well until now. It has been sitting for about 10 to 15 years in my garage. I need help please. I’d appreciate any feedback. Thanks
