70orangeswinger
Where can i find the vin# on a 72 340?
I was thinkin that small blocks had the casting numbers on the side of the block and the other numbers on a machined area where the head and block meet on the front driver side of the block ??On the passenger side just above the oil pan rail on a flat machined pad. Should be 8 digits beginning with a 1 or 2
