Engine parts, tranny, and miscellaneous parts
Dustin The PcP
Sugar Land, Tx
1973 Duster 318 heads with 2,700-3,300 miles on them
1973 Duster 318 camshaft and lifters with 2,700-3,300 miles on it Lifters were marked from where they came out of for correct re-installation.
1973 Duster 318 intake manifold unknown mileage
1973 Duster 318 stock rocker arms with shafts
1973 Duster 318 stock air intake assembly
1973 Duster 318 stock exhaust manifolds
318 2 barrel carb stock unknown condition took of running vehicle about 2 years ago sat in garage on intake manifold since, unknown year.
I switched my Duster over to a 4 speed set up so this can be a manual to automatic swap if wanted.
Small block 904 tranny unknown mileage took out of daily driver
Replacement O'riellys torque converter 1,500 miles
Floor shifter with all linkages and brackets
Brake pedal assembly out of 1973 Duster
Center console for floor shift out of 1973 Duster
Center hump for floor shift out of 1973 Duster
1973 Duster black ignition box unknown mileage came of daily driver.
1973 Duster front sway bar
1972 Dodge charger bucket seat brackets
4 2" billet aluminum wheel spacers 5X4.5 to 5X4 2.75" center bore.
1 8 3/4 A body 742 rear end. 2.7X open diff, no brakes, 5X4 lug pattern
1 NOS bottle with straps and lines 10lb capacity. (14lb bottle + 10lb when full = 24lb)
I will be posting pictures of everything as I can, if you would like a specific picture just let me know. All prices are open make me a REASONABLE offer, but I will be checking pricing before sale. You pay shipping from 77498. Any questions feel free to ask.
NOS bottle and lines
Center hump for automatic floor shift, brake pedal assembly, shifter, rods, and I also have the center console
Billet aluminum wheel spacers 5X4.5 to 5X4 2" thick 2.75" center bore
Small block rockers and shafts no mounting hardware
318 intake manifold and carb
Stock 318 camshaft lift is like .397"/.400"
Stock lifters
Stock 318 heads great shape ready to bolt on and go less than 3,500 miles on them
72 B body bucket seat brackets
More pictures coming and more upon request.
How much for the rocker arms & shafts, shipped to 77306 Texas? Do you take Paypal?
Thanks,
Bill S.
1973 Duster 318 heads with 2,700-3,300 miles on them SOLD
1973 Duster 318 camshaft and lifters with 2,700-3,300 miles on it Lifters were marked from where they came out of for correct re-installation. 45$
1973 Duster 318 intake manifold unknown mileage 30$
1973 Duster 318 stock rocker arms with shafts 40$
1973 Duster 318 stock air intake assembly SOLD
1973 Duster 318 stock exhaust manifolds 10$
Replacement O'riellys torque converter 1,500 miles 30$
Brake pedal assembly out of 1973 Duster 35$
Would like to keep this stuff as a set will consider seperating
130$
1973 Duster black ignition box unknown mileage came of daily driver. 15$
1973 Duster front sway bar 40$
1972 Dodge charger bucket seat brackets 20$
4 2" billet aluminum wheel spacers 5X4.5 to 5X4 2.75" center bore. 80$
1 8 3/4 A body 742 rear end. 2.7X open diff, no brakes, 5X4 lug pattern 400$
1 NOS bottle with straps and lines 10lb capacity. (14lb bottle + 10lb when full = 24lb) 120$
A body torsion bars they are marked .892 and .891 That is not how thick they are though!! These are stock replacement they have about 7000 miles on them will give more detail upon request. 70$
Dustin, if you search for carter bbd or WTB 318 2-bbl, there is a member here that wants to buy one really bad and will pay good money, just a heads up! good luck on the sale:)
