Engine Progress
71Duster
Alberta Canada
Well slowly... It seems I can outwork my ability to buy parts! I'm always shot soemthing, lost in the mail, out of stock or plain doesnt fit. My luck is jsut terrible.
I'm waiting for the res tof my bolts, I got nice 12 point bolt set in stainless for the timing chain cover and the water pump, need a pad for my fuel tank so I can install it and plumb my fuel system... and -cringes- make a hole in the firewall for my autometer temp sender. Thats why I have the larg brass fitting in the intake It'll have a barbed end for a heater hose and has on the back a place to thread my insert into. Mostly I need little things.
yes the engine looks good! I just rebuilt my 340 this last winter myself so i know what your going through! The valve covers do look real nice as it matches the color of te car!
Awesome job! I think we all suffer from the same problem......hang tough, you're waaaaaay ahead of me. I'm just beginning mine after a twenty-five year layoff so I've got a lot of catching up to do! Keep the progress pix coming though; you're giving me ideas! :)
The headers are ceramic coated TTI's they fit very nicely a little close at the collector to the transmission but all in all better then the hooker super comps that came off.
The project snowballed from a fresh engine to some rust repair in the engine bay and painting it and around we went . I cant afford to paint the outside of the car at this time. I had a guy telling me my valve covers look funny on the orange block. I really wanted the direct conn ection ones with no luck.
Can't wait to hear how it sounds through my spintech mufflers though.
Sounds familiar.................. :dontknow:
Looks great, I would not make a hole for the temp sending unit, you should have a grommet under the speedo cable, if not you can route it trhough the speedo one. Keep up the good work.
It'll take a lot of line and I'm not useing the cheesey plastic hose they send for the oil pressure sender so I have brained 4an line. Also I ned to get the temp sender probe through which doesnt come off the factory capilary tube.
