DemonDave
Swollen Member
I have a rebuilt 1982 360 engine that's destined for my Demon in the spring (if it ever gets here!) but I'm having issues with getting a full set of pulleys for it. I've been told that the crank pulley for the small block changed bolt patterns sometime in the late 60s/early 70's from an equidistant pattern to an offset bolt pattern... is this so? If so, when did the change occur so I can focus my search for a set of matching pulleys for my engine?
Thanks!
Thanks!
