Made this stand a few years back very sturdy. Radiator is included and is a Mopar#2898055, 1968 “C” body 318. Gauges are cheap but do work OK. All attachments are adjustable, radiator height, battery box, struts, and gauges. The rear engine stand mount can be removed and transmission mounts used for running your complete engine and transmission if you choose. The engine stand passes the height test for your engine hoist to slide under.
Will not ship, you must pick-up, will help load, asking 500.00 dollars
My zip code is 62656, PM me if any questions Thank You.
