[FOR SALE] engine stand base $30
abdywgn
dismantler
Darien, Illinois
or grinder or transmission stand, limited only to your imagination. The base is 44" long, 29-1/2" wide, 38-1/2" or so tall. The pads are 1/4" and the tubing thickness of the upright is 3/16". There are holes in the upright to allow wires to pass thru in it's previous life. The upright unbolts.
Pick-up only in Darien,IL. Thank-you! Bob
Did you make it yourself or buy it???
Is there a bracket to mount an engine on it???
Will and engine mounting bracket fit in the hole of the upright???
neither, repurposed it.
that would have to be made by new owner.
hmmm, that's possible. maybe if hole was enlarged?
my thought was to weld that tube to the top plate or to another plate
that could be bolted to the top plate, which has threaded holes.
