They had 'em on the pass. side, but only on the early 340 manifolds as far as I know. To tell at a glance, the 273 heat shields had no divider between the two center ports- the 340s did.I had seen those RH style gaskets for earlier 273 motors but have never seen an original 340 car with a RH gasket. Not original to any E-body as far as I know. Sorry, my A-body knowledge is lacking. I’m kind of surprised someone reproduced it.
Sorry I have to clear my emailIs it for sale? Your inbox is full
Mc4759 is the McCord exhaust gasket for the passenger side of the 340 engine. Mc4522 is the companion exhaust gasket for the driver side of the 340 engine. Both of these were included in the McCord MS3076 exhaust manifold set.
McCord listed these in early catalogs for all 1968 - 1973 340 engines, although the initial intent was for the 1968 - 1970 340 engines. Later, McCord merged the 340 application with the 360 engines, MS3195, which is a composite gasket similar to the Fel-Pro exhaust gaskets.
Thank you for the infoMc4759 is the McCord exhaust gasket for the passenger side of the 340 engine. Mc4522 is the companion exhaust gasket for the driver side of the 340 engine. Both of these were included in the McCord MS3076 exhaust manifold set.
As I said above, they are already being duplicated.Thank you for the info
Do you know much might worth.
My friend want to trade me for nos one so he can duplicate this one .
Thank youAs I said above, they are already being duplicated.
Available at Mancini Racing.
$110 right side
$220 left side
$299 for the pair
Search Results
