Hopefully since it just started acting up today I can get by with replacing gaskets and didn't burn up the
Could be burnt exhaust valves. Steel or Aluminum heads?I can throw a new gasket in, but I'm wondering why it won't just blow the new one. Machine shop said the block deck and heads we're fine and would hold the gasket just fine. Especially the fel pros and the low compression pistons
The reason I asked is I also have a set of J heads that was giving me the same issue. No compression and leak down sounded like exhaust. It was building crank case pressure and it had the squirts! Pissed off I had no choice, tare it down. I was hoping it was the head gasket too. but it wasn't swappin spit with the oil/water witch pointed me to the valves/rings. Pulled the head and all appeared to be normal no bad gasket. keep in mind the EGR port in the steel heads have threads in them from the intake and exhaust (small hole, U-shape hole) next to #3 & #5 exhaust valves. Spark plug told me lean. It had fried the exhaust valves and collapsed the lifters. Even if you seal the threads on the intake bolts its possible to get a lean burn condition over time. I want to fill those stupid holes but reading more about them they do have some purpose after the egr is gone other than a carb nut catcher. Im gonna block them.They're iron 360 heads. The Aero Heads from Indy with stainless 2.02 1.60 valves and about 5kmiles. Would love to go over everything with a fine tooth comb. I've got this coming week off, but this is my only vehicle, and there are lots of people on welfare counting on me to go to work, so unfortunately I'm gonna have to tear the heads off and hope I find just a bad gasket.
I agree with you. Water thru the pipes. I ordered a set of the 521SD's I hope the thickness doesn't mess with the compression but .010 across 8 can make a difference. I also have a Torker 340. The mess it leaves under the carb at 3,5-4,6. I didn't have the gaskets that covered the U. There has to be a reason why I had to tare down other than shitty lifter or bad wires/plugs
Custom 3/8 stainless steel fuel line on a Demon 650
View attachment 1715001371[/QUOTE This is pre-tare down.
I should have used 5/16 line. Jives with the pump. Stainless fittings are different thread sizes. try getting the correct adapter for the pump! HA!
I heard they are .060I've always put a lil rtv on all the intake bolts or oil will seep up through. Any idea how thick the 521sd gaskets are?those are what I'm looking at getting. Can have them overnighted
