ValiantOne
Anyone know if I can replace the extension housing gasket in a 833 od without removing the housing completely?
I was wondering if I could unbolt the housing and swing it up like you would to get to the expansion plug, then try to work the gasket over the housing just like you put a tire on a rim.
I bought a gasket set from Brewer's and put the cover and retainer gasket on. The tail/extension housing isn't leaking but as long as I have the trans out???
Thanks,
CE
Thanks,
CE
