[SOLD] exterior parts off of a 73' Duster
dpmalibu
Hatboro,PA
The parts listed below are off of a 1973 Duster. However they will fit other A-bodies (Dart, Dart Sport, Valiant, Scamp, Demon,Duster)
1) 1/4 panel glass $45pr.
2) windshield $ 60
5) Pass side door $ 60
6) Steel hood w/ 4"cowl induction scoop molded in. Scoop is cut out for tunnel ram or blower $175
7) steel hood w/ dual snorkel hood scoop $175
8) Grill w/ head light bezels. Almost perfect. (1) Mounting tab cracked but can be glued. $100
9) Pass side fender $50
10) One replacement 1/4 panel (forgot which side I have) I will update once I dig it out $80
11) K frame ww/ steering box and drag link $200. I have (2) of them
12) Rear HD shock (monroe sensatrac)(I believe they are like cargo shocks. I have spring on them) $40pr.
13) Manual Front disc brake set up. Master cyl., prop. valve, upper/lower control arms, spindles, rotors, calipers $140
located in Hatboro,Pa
I'll take the windshield trim. And the windshield if shipping isn't crazy
door is in primer (spray can) . It has been painted a couple of times. It's rust free and from what I rememeber dent free also. The door has a ding in it and has some surface rust (but that's it) on bottom lip of door.
don't want to see just the scoop right now.
1) 1/4 panel glass ( have have 2 sets)$45pr.
2) windshield ( I have 3of them) $ 60
6) Steel hood w/ 4"cowl induction scoop molded in. Scoop is cut out for tunnel ram or blower $150
7) steel hood w/ dual snorkel hood scoop $125
:cool: Grill w/ head light bezels. Almost perfect. (1) Mounting tab cracked but can be glued. $100
10) One replacement 1/4 panel pass side. $80
13) Rear glass (I have 2 of them) $60 ea.
12) Rear glass (I have 2 of them) $60 ea.
7)Grill w/ head light bezels. Almost perfect. (1) Mounting tab cracked but can be glued. $100
8) Pass side fender $50
9) One replacement 1/4 panel pass side. $80
10) K frame ww/ steering box and drag link $200.
11) Rear glass (I have 2 of them) $60 ea.
prices lowered
2) windshield ( I have 3 of them) $ 50ea
3) Pass side door $ 50
4) Steel hood w/ 4"cowl induction scoop molded in. Scoop is cut out for tunnel ram or blower $100
5)Grill w/ head light bezels. Almost perfect. (1) Mounting tab cracked but can be glued. $75
6) Pass side fender $50
7) One replacement 1/4 panel pass side. $80
8) Rear glass (I have 2 of them) $60 ea.
9) driveshaft for 904 trans w/ 8.25 rear $50
10) torsion bars (like new) # 892/893 $85
11) 8.25" rear stock open diff. (gears unknown) w/ 3" extended wheel studs $200
