[WANTED] Extra Capacity 727 Pan
512Stroker
We are all here because we are not all there.
Freedom, MO
I am looking for a deep sump extra capacity pan for my 727.
Maybe someone has a used one they would part with.
Thanks in advance
I have an old mopar pan number P4120162 chrome pan. Is that what you are looking for?
They are the same on all Diesel trucks and they are heavy duty and have a drain plug. Make sure you get the filter extension. I may have one in the transmission trailer. I collect Diesel transmisions for Diesel builds and heavy duty internal parts such as the six pinion planetary's and other parts. . If you don't find one close to you give me a shout. $50+ride I am in Pa.
Does it add any extra fluid capacity? Thanks
i was lookingg for a stock type as well . got one , well i went and picked a summit finned one also . going with the summit one , way stronger than the stock tin type . it will ad strength to that giant opening in the case bottom , as well as more fluid to the capacity and the fins should radiate more heat as well . and the best part its made
in the usa .
i was lookingg for a stock type as well . got one , well i went and picked a summit finned one also . going with the summit one , way stronger than the stock tin type . it will ad strength to that giant opening in the case bottom , as well as more fluid to the capacity and the fins should radiate more heat as well . and the best part its madeView attachment 1715154914 View attachment 1715154915 in the usa .
Nice stuff!
Mine are all the deep pans . I never had a diesel with a shallow pan as the car 727 has. The pan on a diesel is the same as my extra capacity finned aluminum pan from mopar performance. But it is thick steel. Kind of extra protection for off road if your going there. LOL. I'll see what I have in the trailer and the condition if interested.
yes i looked at alot of them , just didn't want any ads on them . i wish to do without the makers mark . if you know what i mean .
That is a nice pan for the price. Some don't want to spend that for a street car. Diesel pans are all over the salvage yard. I get $50 for one. Some U- pull it yards you can get them for $10-$20. Some gas plow trucks have them you have to go on the hunt. RV's , extra long Vans/Buses. It is the 904 guy's that have to pay to play
