ez efi with port injection
wireweld
South Dakota
Rating - 66.7%
2   1   0
Is anyone interested in an ez efi with port injection? $670.00
These are the part #s:
302000 ez efi
307007 Map
307004 air charge temp
307003 coolant temp
I also have a torker efi converted to efi with fuel rails. $220.00
I live in South Dakota. Buyer pays shipping. I will post pics later or can send them.
Wish I had the money, I would be all over this syst.!
Sorry you have to sell it. Have you had it installed and running on anything?
This is on my 416, which was dynoed at 575 hp on pump gas. The only reason I am selling this is that I am going to build the engine to run on E85 and will have to use a different system.
does that run as a batch fire system? what throttle body are you using?
I bet you could run an 80-88mm TB off anything with a "power elbow" adapter. Look at the ford sites. Its like a 3" tight 90 that mounts to the 4bbl flange of the intake. Dont let the batch fire scare anyone, after about 1500 RPM, everything is firing almost at the same time anyway. Very nice addition to a muscle motor. Really calms the idle down, you can idle it in a drive through without ruining the taste of the food, and throttle response is night and day!
There is a sale pending on the ez efi. I still have the intake and fuel rails for sale. I would also sale the injectors and a filter for 350.00 and shipping.
