Hey everyone
My package just arrived from EZ wiring and Im about to start the removal of the old wiring I will take and post picture of my progress.
Any advise would be helpful
Cheers
I USED AN EZ ON MY 68 FASTBACK. HAD TO CHANGE ALL THE CHEVY PLUGS TO MOPAR, AND WIRE THREE WIRES TOGETHER ON THE IGNITION SWITCH, "ILL BE INTERESTED TO SEE IF U DO TO!" BE NICE IF IT WOULD HAVE MOPAR ENDS AND PLUG INS ON IT. SEAN AT EZ IS PRETTY SHARP, CALL HIM IF U HAVE TROUBLE . (IF HE`S STILL THERE) . I DIDN`T REPLACE THE TURN SIGNAL CAM AND WIRING RUNNING DOWN THE STEERING COLUM CAUSED IT SEEMED OK, IT CAME BACK TO BITE ME IN THE BUT JUST LAST WEEK !Hey everyone
Cheers
KEEP US POSTED ON UR PROGRESS !I USED AN EZ ON MY 68 FASTBACK. HAD TO CHANGE ALL THE CHEVY PLUGS TO MOPAR, AND WIRE THREE WIRES TOGETHER ON THE IGNITION SWITCH, "ILL BE INTERESTED TO SEE IF U DO TO!" BE NICE IF IT WOULD HAVE MOPAR ENDS AND PLUG INS ON IT. SEAN AT EZ IS PRETTY SHARP, CALL HIM IF U HAVE TROUBLE . (IF HE`S STILL THERE) . I DIDN`T REPLACE THE TURN SIGNAL CAM AND WIRING RUNNING DOWN THE STEERING COLUM CAUSED IT SEEMED OK, IT CAME BACK TO BITE ME IN THE BUT JUST LAST WEEK !
Running an MSD ignition, w/ fuel inj. made mine a little diff. So far so good .That would be helpful doing my car over the winter.
I didn`t use any relays that didn`t come w/ the EZ, or fuel inj. kit, no need. The wiring is much better than stock too.Same, will running MSD and Holley sniper efi. Plus I bought an under the hood 6 relay/fuse box to run lights/horn/fan etc...
P M sent.Tonight I will removing all the old wiring from under the dash.
Only thing that has me a bit concerned is the fenderwell headers and the routing of the wires from the dash to the lights
I did an EZ kit on my Dart. Moved every thing that makes it run into the car under dash. It's a little tricky, but wasn't that badP M sent.
^^^I did an EZ kit on my Dart. Moved every thing that makes it run into the car under dash. It's a little tricky, but wasn't that bad
