[WANTED] Fan Blade
kmabry
Arrington Tn
looking for cooling fan blade 2863213 for my 1968 barracuda formula s.
also the original water pump pulley.
it has no air or power steering.
Thanks kenny
kenny. I have same application but used 2863215 blade which I believe has greater pitch. Do I have correct fan? Jeff
Jeff, the 2863213 is the original fan # but if that works well that's probably what I'll end up using.
Thanks!
Nothing like the real deal. My 383S uses the 2863213 and correct shroud! Do not Compromise. JMO!
They are out there for sale!
