fan problem
mopar7172
Banned
las vegas,nv
i just put a 68 383 in my 72 plymouth duster. it had a slant six k-frame,i used with k-member and just bought the conversion mounts. notch the k-member as well. i notice the fan isn't total center with radiator.it looks like it needs to go over a 3/4-1 inch over to be center. anybody else have this problem?
It's probably never been centered. Have you seen radiator fan shrouds that are offset to the passenger side. I wouldn't worry about it. If your running a stock radiator and shroud just make sure the fan clears the shroud on all sides.
ok thanks for the replys. where do u i get a off set fan shroud at?
By looking at them you can see all of them are offset. Which one you need depends on which radiator you have 69 back was a 22" round top style radiator. 70 and newer uses a squared off tank style which is 22" also. So it depends on what radiator and body your wanting one for.
